Re: 36lbs maxed??
LT1 and V6 cars have the same pump set up. (At least the 3800 in my 97 is identical to an LT1 car)
It's a plug and play 255 with instructions and the hotwire. If you don't upgrade the pump wring it won't give you full voltage which means the pump isn't really working to it's potential!
The injectors are more $$ if you want them flow matched, but at this power level I don't think it's really required. If you were going to anything larger I would definitely say match them.
Originally posted by Watazz
View Post
