Question about cats - FirebirdV6.com/CamaroV6.com Message Board
Question about cats
  • Question about cats
    Will taking off my catalytic converter noticable change the sound coming from the exaust?
    another question.. can a cutout be installed where the cat was?
    Re: Question about cats
    yes louder, better, improved fuel economy
      louder, raspier, no noticeable gain in gas mileage or power
      1996 Chevrolet Camaro
      1995 Buick Park Avenue Ultra
      --Appearance Moderator--
        Car will smell like 1972. :) There is a small gain to be had, but modern passenger car cats are simply not as restrictive as they used to be. If you have no emissions, rip it off, if you do, go high flow.
          no it wolnt
            thanks guys. so do i just have a 2.5" pipe welded in where the cat was so that it is one straight pipe?
              yeah, that's what i did.
                so if you take off the stock cat and just weld in some straight pipe it will sound better?
                  Heh, i just cut mine off. Beat out the insides and welded it back on. Easier than buying new piping and measuring. I'm sure it could disrupt flow a little bit but eh, I'm pretty positive the catalyst slowed it down a lot more. And yeah, it sounds better for some.. worse for others. I suppose its a matter of opinion. I like it.
                  TEAM C6V6
                    Originally posted by cam98aro
                    no it wolnt
                      I actually just did this, prior to the cat swap i had a magnaflow system and it sounded good, but had some rasp too it. I bought a magnaflow high flow cat, and now thre's little or no rasp, and it runs so much smoother, a little better tone too. I would get a high flow cat, with a simulator, and be done with it.
                        my stock cat went bad on me so i just got a carsound magnaflow.
                        at first it was pretty loud but once it broke in it quited down.
                        Didn't need a sim. just get a high flow and be done with it.
                        -Y87
                        Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
                          If you remove your cat you can expect a little less back pressure. Since it may relieve some back pressure, the car will feel a bit weaker down low, and pull more up top due to the torque curve moving up higher in the RPM range. Without a cat the 3.4 sound okay, pretty raspy up top though. With a high-flow cat, it sounds pretty good, probably just as loud, but less raspy.
                          Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
                              yessir
                              http://www.bowtiev6.com/
