If i port my tb what would I have to do with the maf and the screen And is it even worth it?
porting tb
Re: porting tb
do not cut the center pole out if you are going to port it. If you cut the pole then you will have to change things up to make it work including using tuning software to rework the MAF tables.
Our TBs are huge already, you are not maxing out the TB, just leave it alone unless you have some FI which is feeding it a ton more air
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
