So i took my car to the track after i got my full exhaust done from headers to highflow cat and catback and my times werent as good as last time when all i had was catback. it was warmer last night than a year ago when i went. Could the egr leak cause a power loss or is that ticking just not matter. I might need to clean my fuel injectors also its been a while since I have i think you just buy the **** and poor it in
EGR leak power loss?
Re: EGR leak power loss?
it was probably the temp difference. But you can just get some type of filler to fix that anyway, i know mine got really bad and it was really really really anoying till i used tome jb weld on the *****
false KR\'97 Camaro M5 Y87 3.23 LSD, homebrew CAI, highfloCat, Flowmaster catback, Pacesetter headers, specstage3 clutch and aluminum flywheel, !egr, 2kW system.<br /><br />Possible L67 bottom end w/ abbott heads and a turbo in the works... gotta do more homework
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...10 hours ago
