I don't think I will but just to confirm if I get the full magnaflow catback system part #15693 will I throw any codes? It replaces the s pipe to the tips without removing or replacing the cat so I should be fine right?
Will I throw any codes?
Re: Will I throw any codes?
You should be fine if you keep the stock cat there even if you were to put a high flow there you would still be fine. I think you get the code mostly for going full 3inch. and the magna flow is a 2.5inch if I'm not mistaken. I mean I had a 3 inch Hi- flow with my stock system and for 2 years it didnt throw a code and still hasnt for my TDs. But let the ones that have had this prob. commment in before making a move.
no codes. just make sure your post cat 02 sensor is re-installed in the new s-pipe
