Lower intake spacer? - FirebirdV6.com/CamaroV6.com Message Board
  • Lower intake spacer?
    Lower intake gasket sprung a leak tonight so i was gonna ask you guys what you thought bout this since I gotta fix it now.
    http://www.cheetahonline.com/products/g3023.html
    Re: Lower intake spacer?
    yea, you're gonna have serious clearance issues putting a half-inch gasket under the intake
      hmm, thats cool, never seen that befor, and 1/2 an inch will NOT cause clearance issues. However a regular gasket will run you like $20 plus you get a TB gasket. Its a cool concept and it may be good for some hp, but not enough to even feel. I would go with a stock gasket.
        While it probably wouldn't hurt to add some runner length to our intakes, that spacer will completely interrupt the flow through the intake ports.
        <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
          good point, it would really interupt the flow
          / -upper intake
          | -spacer
          / - lower intake
            yea, looks like I was wrong.
            to the OP, you'll gain much more from buying a stock gasket and eBaying an intake setup (CAI if it's a 97 or older, whisperlid if it's a 98+) than buying a half inch gasket to stick in there
              Yeah, you're right. But how about porting the spacer to match the intakes? If possible, I think it's a good find.
                well I go to School for mechanical engineering and thats sorta what I thought the upper and lower runners are matched but the spacer is straight so someone needs to redesign this thing.
                  with the way the are setup it cant be done.
                    would be cool if someone could use this for a nifty direct port setup!:naughty:
                      Yeah, it wouldn't be perfect. But you could smooth/round out the angles and make it like slight backwards "S". Well, that's the image I have in my head.
                        your talking about what is also know as a "plenum spacer" (lower and upper)... word
                          how would it interupt the flow????? i kinda like it
                          2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
                            because the ports on the intakes are angled toward the heads. The spacer looks to be straight.
                            to this
