header advise - FirebirdV6.com/CamaroV6.com Message Board
header advise
  • header advise
    what headers, when installed can be hooked up to the stock y pipe?
    since i'm doing the duals..... i might as well research headers for it too eh?
    00 Camaro with the Y87 Package!<br /><br />stock times 15.59 @86.3mph with a 2.25 60\'
    None....and if your are doing duals....why do you need a y pipe.
      the duals will be matched up to the stock manifold location. so if a header set would hook up to stock y pipe location... would it not be presumable that it would fit to the duals?
        If your doing duals you won't have a use for a y-pipe it will have to be custom bent piping coming from each header.
        00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
          okay....i KNOW i wont have to have a y pipe.
          what i'm asking, since the duals will mate with the stock manifolds in the stock location, is if any brand of headers will mate correctly w/o any modification to the headers or the dual setup.
          HENCE the questio if they would mate witht the stock ypipe..
            No...all 3 different ones require a different y pipe.
              Odd question but if your going duals then planning on switching to headers later all it would take would be a slight adjustment to the piping that met the new headers.
                thanks for the replies guys!!
                anyone know of a place that can give me some info on designing headers? because i think i can have some long tubes made for dirt cheap....
