I have a 2002 camaro which I just installed a K&N FIPK on. I was wondering what, if any benefits there are to removing the MAF screen.
Unscreened MAF??
Originally posted by shenanigans:
Worked fine for me but some suggest its bad ro remove it.
The purpose of that screen is to decrease the turbulence of the air entering the TB so that the MAF can read the airflow accurately.
I've also heard that it will hurt an A4 more that it would/might hurt an M5. So I'd recommend keeping it in.
I ran with and without mine for a while, and there's really no noticeable power difference. So I'd say just leave it in...just in case...1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
I popped mine out and seem to run just fine, and actually thought I felt more uptop but ehh..-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
99+ its fine, 98 and older is bad. Yhat's just the common consensus, not too sure why it's like that.\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
Originally posted by 99v6cam:
99+ its fine, 98 and older is bad. Yhat's just the common consensus, not too sure why it's like that.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Speaking of throttle bodies...Where is the throttle cable located on the 3800? On the LS1, it is very easy to locate right at the throttle body, but I have looked all over the V6, and I can't find a cable of any sort. Is it a totally different throttle system, or am i just blind?2002 Camaro A4<br />K&N FIPK<br />Ravin exhaust<br />15.64 @ 90.11 MPH<br /><br />_ _ ___________________ _ _ <br />2004 Quicksilver/Black GTO M6<br />Stock except !CAGS
you don't have a throttle cable because yours is a 2002 and as of 1999 they are electronically controlled ;)\'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
