So whats the best way to remove the studs (on the stock manifold) that didn't come out with the nuts? I still have 3 on the driver's side in there.. (including one that is broken but I can still grab it with plyers)
Pacesetter install in progress
00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own riskTags: None
Run another one of the nuts onto the stud right up to the remaining nut...now with two on there, torque on the one closer to the head. This way the nuts will not come off, but the stud will [img]smile.gif[/img] Make any sense Bo? Call me if you need to. 438-6977<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
k I understand that.. what about the one I broke taking the heat shield off =)
oh and by the way that didn't work.. both of the nuts came off lol
[ January 01, 2004: Message edited by: ReodDai ]</p>00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
damn.. mine came right off with a VERY VERY SMALL wrench... it was easy... wth96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
yea 5.5mm socket will get them off.. except eh one I broke... vice grips won't stay on it but the headers are on either way. If my mechanic at work can't fix it to the exhaust shop it goes to get that stud removed.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
<blockquote>quote:</font><hr>Originally posted by ReodDai:
yea 5.5mm socket will get them off.. except eh one I broke... vice grips won't stay on it but the headers are on either way. If my mechanic at work can't fix it to the exhaust shop it goes to get that stud removed.<hr></blockquote>
You gotta grip them hella hard....i had the vice grips closed down and used that to lock them down onto the stud....took about 15 minutes per stud.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
<blockquote>quote:</font><hr> Run another one of the nuts onto the stud right up to the remaining nut...now with two on there, torque on the one closer to the head. This way the nuts will not come off, but the stud will Make any sense Bo? Call me if you need to. 438-6977 <hr></blockquote>
its called double nutting!! [img]graemlins/fluffy.gif[/img]
BTW, if both nuts came off you didnt tighten them together enough...<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
