i'm thinking about getting the tsp rumbler this summer and i want to put my b&b tips on there, but after looking at this pic http://www.texas-speed.com/catalog/r...lercatback.jpg i see that the passenger side is slanted, then goes straight at the end. how will i be able to put on exhaust tips that are longer than that straight part? can an exhaust shop cut that and fab up a straight part to install my tips? my tips are over 12'' long and the rumbler has about 4'' of straight pipe for the tip. i need suggestions before i hack off my old system and come to realize this won't fit right w/ my current b&b tips. (i'd rather keep the b&b quads than have it sound better if it won't fit)
TSP rumbler & B&B tips?
if you look at the passenger side it is slanted outward, then has a kink in it to make it go straight out the back. if i install my tips on it the way it is now the passenger side tip will be pointed outward b/c it is longer than that 4'' section of straight part.94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
check out this pic. http://images.cardomain.com/member_i...63_89_full.jpg the tip is longer than those oval tips so i will need to mount them farther back on the pipe. the horizontal line shows about where i will have to cut the pipe to get my tip to fit right, the vertical line shows that the pipe now is not going straight out the back. if i stick the tip on the way it is now it will come out sideways. if i mount the tip on diagnally so it comes out straight, it won't come out the right part of the rear bumper. see what i'm saying now?94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...6 days ago
