I'll be doing this within the next two weeks, and need to know how to avoid getting knock retard. My plugs/wires have about 9k miles on them. Should i change them out already??? What would be the best, the NGK 6's and Taylor wires?
Thanks for all help.
Scott
:edit: These are the RKSport headers.
No i didn't pay 500 for them, muahahaha!
[ January 24, 2002: Message edited by: Scott Black ]</p>
Why do you believe that you will be getting KR by adding headers? The computer determines the KR to eliminate pre-ignition. Who said that the headers would change the KR?
[ January 27, 2002: Message edited by: FirebirdGT ]</p>
Robert - owner www.FirebirdV6.com"Mid-life crisis? I'm way beyond that!"
Well it was because whoever had their CIA headers dynoed and had a whole bunch of it, but i didn't really read why it happened except something about he used cheap plugs or something. So it made him lose a bunch of power. That's why. :D
So they have nothing to do with each other huh? Well don't i look like an *** ! [img]smile.gif[/img]
The only reason for getting KR on a mod like that is if your headers were vibrating against something, causing the Knock sensors to think it is knock. Othere than that, headers should REDUCE knock.
<blockquote>quote:</font><hr>Originally posted by DEE97GTP: The only reason for getting KR on a mod like that is if your headers were vibrating against something, causing the Knock sensors to think it is knock. Othere than that, headers should REDUCE knock.
DEE<hr></blockquote>
And that is partly because they usually cause the car to run a bit more rich. Use headers and full exhaust in conjunction with the MAFT+, and you'll see even more power, theoretically, by leaning to mixture out just a bit...
