did you install the exhaust yourself or did a shop install it? i notice a lot of people are having problems saying their exhaust is really low and for some it might be hitting something. i'm probably going to switch to a rumbler pretty soon, but my car is lowered so an exhaust that hangs any lower won't be a good thing. i'll get mine professionally installed and welded so i hope he will be able to put it up as high as possible.
people w/ rumbler and have fitment problems (too low or hitting)
I'll let other help field this one...but a quick note. It has alot of adjustability built into it on purpose. We knew that the 3" pipes would take away some clearance, but any good exhaust shop that has ever put a catback on these cars should be able to work it just right to get all the clearance you'll need....even with a lowered car.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
I had mine installed by a shop and I have no clearance problems. It appears to only depend on the skill of the person installing it.
The only clearance I lost was from the bigger diameter pipe. When you look under the car you can barely tell a difference.SLP CAI, K&N, Whisper Lid, 180* thermo, manual fan switch, 3.42 gears, Auburn Pro LSD, Wester\'s PCM Tuning, TSP Rumbler, High Flow Cat. Best Time: 9.909@71.58 (1/8 mile)
