Can the ball joints be cut off on headers? - FirebirdV6.com/CamaroV6.com Message Board
  • Can the ball joints be cut off on headers?
    i've got a set of coated pacesetter headers for my 3.4 and they leak at the ball joints that connect the headers to the y-pipe. the exhaust shop i took it to said the pipe is bent wrong and can't be tightened down to seal it off. i was thinking if i could just have the ball joints cut off and just put regular exhaust piping it will solve the leaking issue. can this be done? i would like to avoid having them welded incase it needs to be disconnected.
    i was also thinking i could possible re-route the y-pipe. instead of coming down from the driver side header along the frame then going into the y-pipe; i was thinking i could have it come out and around similar to the ls1 setup. http://dw-zone.gotdns.com/hooker_y-p...pipe-done1.jpg
    it won't be this far back since our cat is farther up, but this is a similar idea to what i want. i think my pipe is hitting the frame right under the engine and this will give it all the room it needs.
    94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
  • LETZRIDE
    New Owner!
    by LETZRIDE
    I am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...
    5 days ago
    Little work today
    Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...
  • LETZRIDE
    Tom Henry RS Pt 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff
    by LETZRIDE
    Building the Tom Henry RS
    Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff.
    By: Hib Halverson
    At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6.
    Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...
    02-07-2020, 10:30 PM
