Well I have my carsound cat but can deceide how to install it. The stock cat has a metal bracket that appears to be bolted to the old cat or something, and then the spipe. Should I chop the Spipe off and weld it to the new cat and then what to do with that bracket thing? Anyone done this?
installing cat
um, I think the stock system is a welded cat on both ends. I don't remember a bracket. The stock s pipe has a band clamp to the mid pipe, though.
Are you just changing the cat? 3" to 2.25"?
If so, on mine...with the welded cat...cut the cat at the y pipe right up close to the cat weld line as possible. You new 3" in cat will slip over the y pipe. YOu can clamp it with u bolt and weld later if you like. (i like clamp...if cat goes bad I can just take it off rather than loose meat of the Y pipe everytime I need to cut it off)
Next, the 2.25" out collar of the cat will slip over the stock s pipe...do the same there and cut the cat off the s pipe as close to the weld line as possible.
the exhaust system design varies from year to year. stock exhausts have a bracket (attached to the rear of the cat) that mounts to the transmission x-member... that's why your exhaust seems to change note when you add a stiffer transmission mount.
a shop will probably make something that goes 3", fill with weld to 2.5", fill with weld to 2.25". not a very sweet way to do it but there isn't much other choice unless you go to a full 3" exhaust.
yes, your pipe is 2.25 so you'll need a reducer. nothing a shop cant do cheap
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...5 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...3 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
