i just installed my kit. while i was installing it, one of my filters fell off. i went in from the bottom to re intall the filter. my question is; can i just leave this plastic shroud off? would it help getting more air? or should i just leave it alone??
SLP cold air kit help
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
I personaly would leave it on but I remember reading something a while back about using the cold air intake system from SLP. What the person did was take some sheetmetal and make a scoop type thing and cut out a hole in the shroud thing and screw it on there. Altho I think that a lil extream but it does make since with what he did.
I made a scoop on mine also, That was short lived tho, it was ripped off. I don't think I ever did put the plastic peice back, you will be fine.2005 Cavalier LS Sport M5<br /> <a href=\"http://members.cardomain.com/firefighter8615\" target=\"_blank\">http://members.cardomain.com/firefighter8615</a>
I recently ran into a problem where when I drove my battery gauge showed low voltage. I compulsively replaced the battery and it was still doing the same...5 hours ago
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...6 days ago
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...3 weeks ago
by LETZRIDE
Building the Tom Henry RS
By: Hib Halverson
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 10:30 PM
