What would happen if I put propane in the intake?
I saw these dudes putting propane in a intake of a truck on HP-TV. Does this only work on diesel engine?
Propane would be alot cheaper than Nitrous to refill and stuff.
propane and gasoline wouldn't work, it would just run rich. however, mix propane with deisel and it is just like n2o. has a lot to do with the high compression ratio of the deisel engine and the high temperature that propane burns at. i also don't recommend putting propane into a gasoline engine at all unless it has forged internals. because of the high temperatures of the burning propane it causes the parts to wear out a lot faster.
wonder how i know this? i convert cars to run on propane for a living. :D
