is it a good idea to replace the precat o2 sensor with it?
where to install A/F ratio gauge sensor?
Re: where to install A/F ratio gauge sensor?
Do you mind if you always have that code bothering you?Wait, Is that a V6 or V8?
I'm pretty sure the PCM needs the pre-cat O2 sensors (there are 2, one on each manifold.) The PCM uses these to control the A/F ratio and it probably wouldn't run right at all without one of them. Now the POST-cat sensor is another story. The PCM only uses it to check performance of the cat. You could do without it, but it will throw a code at you.
(Somebody chime in if I'm wrong, it's been known to happen.)
two upstream and one downstream i thought.Wait, Is that a V6 or V8?
You really only need the 2 manifold O2's for fuel trims, I'm only running the 2 right now plus the wideband. You will need tunning though for it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by 97RSSM90 View Postis it a good idea to replace the precat o2 sensor with it?<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a><br /><a href=\"http://www.chitownracing.com\" target=\"_blank\">www.chitownracing.com</a>
i have a aem wideband. i thought the sensor right before the cat was to measure catalytic performance along with the post cat sensor and wouldn't be needed when i get my tune. ill see if i install a bung next week then.
The sensor before the cat can be used , I'm not usiing any of the cat sensors and my car is fine. I just use the manifolds and a wideband and it does great. Of course I have tunining on it and a turbo so its alittle different.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Watazz View Postreplace the one before the cat WTF
X2, try and make it easier but let them do what they want.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i have a supercharger lol oh ok. so its ok to do it on my car then? i justed wanted to know if the pre cat sensor on 97s used this for a/f ratio. im getting a dyno tune soon so im sure they can delete the cat codes.
