PCM Removal - FirebirdV6.com/CamaroV6.com Message Board
PCM Removal
  • PCM Removal
    Has anyone ever removed their pcm? What precautions do I need to go through? I'm considering sending my pcm to asechip.
    just be sure 2 disconnect the negative battery terminal first. then take off the pcm wiring harness its 2 bolts one on each connector, pull that off and pull the pcm out. its a little bit of a bi*** getting it in but you will figure it out
      I've removed mine a couple of times.
      It is a ***** to do!!!!!
      Yup, dissconnect the battery.
      Then unscrew those bolts holding in the wiring harnesses (two of them)
      The computer sits in a black thing.
      I found it easier to remove the bolt holding the blacxk thing in.
      Then remove the computer on its own.
      I tried to remove the computer still in the black thing but I could not.
        The only precaution I can think of (other than disconnecting the neg. battery cable) is to WEAR GLOVES! I ended up drawing blood about 4 times in the process of taking out and putting in my PCM. [img]graemlins/crybaby.gif[/img]
          Cool. Thanx for the info fellas.
