OK I am living the very worst of both worlds. I started out doing a simple cam swap and found a wiped out cam lobe and 3/4 of a lifter. (see my post in Advanced Engine) The broken lifter took out at least one cam bearing so now I have to pull the motor. I already have the radiator out, intake and front of the motor off.
My plan is to pull it out from the top using the equipment I have at home, rebuild the motor assemble it on a stand then tow the car and motor to a friends house and use his lift to put it all back in from the bottom. Trust me this makes sense because the trailer and lift are an hour from my house and the car and I can have it out in less time than it will take me to just transport it. (an hour to get the trailer, an hour back to get the car, and hour back to his house with the car)
My question is do the heads and exhaust manifolds HAVE to come off to get it out the top? IT looks like there is enough room to bring it forward and lift it out once I disconnect the trans.
IF the heads HAVE to come off can they be pulled with the manifolds still attached, this will save me time and some busted knuckles.
Thanks,
Scott
Thanks,
Scott
