Rear main seal? - FirebirdV6.com/CamaroV6.com Message Board
Rear main seal?
  • Rear main seal?
    Ok so today I go to get my oil changed at the shop today and they showed me all the oil that was on the Ypipe and bottom of the bell housing.
    My clutch also slips if I give it some throttle at a lower RPM. So Im guessing oil is causing that problem...
    So is it my rear main? How hard is it to replace?
    1998 Camaro....
    98 Camaro 3.8 M5 Y87 | 99 Camaro LS1 Z28 T56
    Re: Rear main seal?
    very hard. have a professional do it
    Team NoVa
      Re: Rear main seal?
      same problem here... it sucks. got to drop the trans to do it...
        Re: Rear main seal?
        paid $550 to do mine
        1997 Camaro LS1 RS
        1994 Camaro - Sold
        1999 Trans am Vert - Sold
        A Few Mods....
          Re: Rear main seal?
          And the sad part is..................THE PART IS ONLY 19.99
            Re: Rear main seal?
            Part is 12.99 here and I already planned to pull the tranny. Ive pulled them before and wasnt very hard to me...
            So I take it you guys think it is the rear main?
            After tranny, clutch and flywheel is pulled, whats left?
            Where you at Kristen?
              Re: Rear main seal?
              get a screw driver and pry it out. put the new one in.
              Team NoVa
                Re: Rear main seal?
                you have answered everything...
                Team NoVa
                  Re: Rear main seal?
                  its not hard at all replacing the rear main
                  the hardest part is getting the top bolts out of the trans so you can get the thing out
                  make sure its not your oil pan gasket though
                    Re: Rear main seal?
                    damn thats not bad. i need to do mine soon, its starting to leak pretty bad now.
                    Follow me!
                    Or this
                      Re: Rear main seal?
                      Add some die to it and make sure it is the rear main. Then just use a blacklight. I always use die first , oil , A/C , and tranny. Will let you know if you have any other spots also.
                        Re: Rear main seal?
                        Im sure the oil pan gasket is leaking as well. There is oil just about everywhere, and really bad at the bottom of the bell housing. I dont think the die will help... Great idea though.
                        Im guessing Id have to pull the motor to put in the pan gasket...?
                          Re: Rear main seal?
                          Wow
                          Sweet
                          Good to know
                          It both Im sure.
                          $384.06 here
                            Re: Rear main seal?
                            no, but you have to lift it a little bit
