I have a problem i do not know if my car has keyless on or not because i got it from a wrecked car dealer do 99's come standard with so then should i just buy the remote?? PLease help!!
Keyless Entry on 99 F-bird
Check the RPO codes to see if your car is equipped. Looks like AU0 is keyless entry.
http://tech.firebirdv6.com/generalspecs.htmlMatt
1998 Mystic Teal Camaro M5
It should be on the drivers door. A little metal piece attached to the door will have a bunch of 3 letter codes on it. If you do have it you can buy a new remote off ebay and you can find the programming instructions on here somewhere.<a href=\"http://www.onid.orst.edu/~waltejam/\" target=\"_blank\">98 Bright Red Camaro</a><br />Too many mods to list....check my website
Originally posted by 99firebird99:
Hey where are they located i cant find them on my drivers side door or in the glove box??2006 Tiburon
aye, it's just a bunch of random codes.. should definitely be inside the door~The Guru\'s Guru~<br />1999 Camaro,K&N,!MAF<br />!airsilencer,3.08s,<br />NGK-TR6\'s,Taylor Blue 8mm wires,FRAM,A4,Catco Cat, Magnaflow 3 inch catback,transgo shift kit<br />Waiting: RK sport headers, custom y pipe electric cutout<br /><a href=\"http://www.cardomain.com/id/divinejc\" target=\"_blank\">www.cardomain.com/id/divinejc</a>
of yoi have the sticker with a bunch of 3 digit codes, thats the option sticker
if you don't have that code, you don't have keyless entry (assuming that is the right code)
But simple solution, find a friend with a f-body and test program their remote on your car ;) I've got 4 remotes here and most of my friends with f-cars have a fewextras
Ryan1998 Ws6 Ta M6 #370 Bright Red<br />Custom \"NX\" style switch panels $35<br />Plug in fan switches $50 <br />SLP lid, Pro 5.0, Corsa, Custom Fan switch<br />....vortech waiting to be installed.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...14 hours ago
