starting problems?? - FirebirdV6.com/CamaroV6.com Message Board
starting problems??
  • starting problems??
    for some reason my car hasnt been wanting to start up lately it kinda turns once real slow then again real slow then about 3 quicker one's and then starts it seems like its not about to start but it starts everytime anyone know what could cause this?
    Re: starting problems??
    check your battery
    2000 3.8 A4 Pewter Camaro
      Originally posted by BLLDOGG
      check your battery
      tried that it was the first thing i went for could i maybe need to sand the terminals?
        Are they dirty or corroded? If they are then yes, by all means clean them up real good. Once they are clean, if the problem persists, check the ground and power terminal wires going to your battery.
          could also be the starter
            yup ............. my 96 and 98 both i had to change the starter because of starting issues ................... your symptoms are similar to my 96 ..........when u put the key on 2nd click before the start, do you hear the fuel pump noise? ..........
            09 Nissan 370Z MB M6 Sports Package
            www.the370z.com
              You can take your vehicle to Autozone and they can check your battery and starter while it's on the vehicle. You should check your battery first as well as the cables for the battery. If they are corroded, replace them. A lot of people don't realize that the corrosion can go beneath the insulation and create a poor connection. Cleaning the connectors, in this case, will not fix the problem.
