engine tick video - FirebirdV6.com/CamaroV6.com Message Board
engine tick video
  • engine tick video
    http://s33.photobucket.com/albums/d8...t=DSCN0280.flv
    im not sure what it is, ive gotten theories from egr valve,exhaust leak,rockers,loose rocker arm,lifters etc.
    anyone know for sure? its a 94 3.4 with 179k on the clock.
    Re: engine tick video
    you know the sound quality isnt that great but it kinda sounds like rocker arms ticking or an exhaust leak
      naw, thats a lifter.
        +1 definately sounds like a lifter is going limp.
          Damn and the last thing you want is a limp lifter.
            Is this an inuendo? lol.
              yeah I was going to add maybe you should throw a blue pill in your oil and see if it "perks" up. I figured that would be a bit much though.
                lmao.
                  lol thats funny but your right. Add a quart of Lucas and if the sound is reduced then its probibly a lifter. If the sound doesnt change then its more than likely an exhaust leak. Could be something different but that sounds like one of the 2.
                    alright guys i bought a stethoscope and put it to both valve covers and the drivers side sounds a lot louder than the passenger. like metal to metal contact. any ideas? i think im just gonna rebuild it and have them put a comp cam in it and port the heads if they can.
                      try pulling the valve cover and tightening it down first. It doesn't ALWAYS work but it's a try...
                        eather one huge exhaust leak or a lifter
                        get a wood dowl and put it on the block and intakes and stuff...... and then put your ear on it . if it inside the motor you will find it
                        www.turbov6camaro.com
                        1997 3800 Series II Camaro
                          i also idle at 1100, so iono.
                            old school trick, from an old guy... let your car get "stone cold" and spray/poor soapy water around the ex gasket, start your car and see if you get any bubbles. (found one on a 87 van that way).
