T-Tops, HELP!!! - FirebirdV6.com/CamaroV6.com Message Board
T-Tops, HELP!!!
  • T-Tops, HELP!!!
    Hey, I'm trying to help my girlfriend install the T-Tops lock back in her left T-Top. What I need help with is, how do you get the handle off? I can just slide that little plastic cover right off once I get that handle out of the way. Thanks in advance!!!
    - Matt<p>Red 1993 Camaro Z28 M6<p>My <a href=\"http://brightred93z28.fbody.com\" target=\"_blank\">Webpage</a>
    There is a little retaining clip in there that looks like a 'U' with little indentations towards the top that hold it in place. when i did mine I just pulled up on the handle easy so not to damage it and it came off. then when putting it back on line up the handle in the right spot and slide the clip back into place with a needle nose plier.
    1996 Camaro 3.8<br />Edelbrock Exhaust, SLP Intake, Bosch, Platinum +4 Plugs, Accel Wires, SLP fan switch<p>\"Let the good times roll\"
      Sweet man! Thanks for the help! I saw the 'U' clip but I didn't think much of it. I drive a convertible, so I'm kinda T-Tops illiterate :D
