possible to remove speed limiter? - FirebirdV6.com/CamaroV6.com Message Board
  • possible to remove speed limiter?
    Is it?
    The Surgeon General never said anything about smokin\' a FORD
    Is your car an 02? If so get the hypertech pp+
      I am working on a cheep solution.
      www.jetchip.com has an SCU2000 (something like that). It gets rid of the speed limiter and compensates for gear and tire changes. However, it is around $250.
      If anyone has one, does the unit simply stop the speedometer at 100mph or will it peg the speedo? I am just getting an idea of how it works, because I can do that for around $10.
      <b>LS1 RX7! </b> &#0124;&#0124; <a href=\"http://www.no-bling.com/image_galleries/index.php?action=viewgallery&gallery=galleries/eyeoutthere_LS1_FC\" target=\"_blank\">Full Gallery</a> <br /><br />LT1 Header Informtion/survey
        I am pretty sure its not just a stop on the speedo. It either cuts fuel or ignition, something like that. Because its activated by rpms, if you put in 4.10's for ex. you're top speed would be like 96 mph.
        Josh<br />96 Red Firebird <br />SLP intake, zex nitrous 75 shot(for sale), purge kit, MAC lca + phr, Jamex springs, flowmaster 80 series, ES tranny bushing, SCR subframe conectors, Harlan shiftlight, A/F guage, MSD dis-4, Accel wires w/ NGK tr6\'s, foglights, stereo, zexel torsion LSD, Walboro 255 pump, and more.<br />Looking for: 1le ds, nx wet kit + accesories
          Depends on your year.
          The only company I've found that makes one right now, for the '98, is www.asechips.com. You have to send them your chip, so the car is down until you get it back. (well, except the jet chip, but all the feedback I've seen here is negative on this brand, so it didn't make the list.)
          There are some people here who are working on their own reprogramming solution, but not too sure how far along they are. Part of the problem is that the chips were different from 96 to 97 to 98 to 99, so they have to re-figure out everything from year to year.
          The hpp3 people seem pretty good on the newer years.
          Another thought is getting a pulse modifier, to trick the system into thinking you are going slower than you really are. I had considered halfing the pulses, then just have to double the reading on the speedometer to tell how fast I am going. I guess if you don't mind the small print, you could cut the pulses so that the kmph numbers matched your true speed. The problem with this approach, is your rpms will still be up, so you will probably get a transmission slipping SES code, since the mph won't be up there to match the rpms. You might be able to also lower the rpm pulses, but then the system is going to think the engine is turning slower and won't ramp up the timing, fuel, etc. like it should.
          \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
          • Andy H
            Hello everyone!
            by Andy H
          • 3.4 slow to go
            hey there strangers!
            by 3.4 slow to go
