A few days ago I wrote in about some problems I was having w/ my factory alarm remote. It wasn't working worth a crap! I even had to drive home w/ my alarm and lights going off. Well here is what I did and so far it is working like new again. First I used a real light sandpaper on the black contacts behind the buttons and then cleaned them off with a clean rag. Then very lightly I sanded the metal contacts on the green panel inside the remote. Now after I did this it started working but I still noticed I had to press down real hard to get it to work. The reason is because after pressing down on the lock/unlock buttons so many times it kinda pushes it down on the inside. So what I did was I cut out a small rubber square(from a garden hose) and slipped it under the panel right below the lock/unlock buttons. I closed it back up and now it works like new(and you can't even see all the riggin I did to it).Hope this helps someone else low on cash. [img]smile.gif[/img]
I finally fixed the problem w/ my factory alarm remote..
1999 Firebird (black)<br />Y87 package<br />Whisper lid<br />FRA<br />Raised airbox<br />K & N Filter<br />Removed MAF screen<br />180 thermostat<br />3\" catalytic converter<br />Cat-back exhaust<br />Flowmaster<br />\"Fool you can bet, that I can dance underwater and not get wet\"Tags: None
I had the same problem with a phone I had. I dropped it in the trash because I could not get it to work. Thanks for updating us [img]graemlins/thumbsup.gif[/img] .White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
No prob! It's just a way of getting a bit more life out of the remote b4 you go out and spend 30.00 bucks on a new one.1999 Firebird (black)<br />Y87 package<br />Whisper lid<br />FRA<br />Raised airbox<br />K & N Filter<br />Removed MAF screen<br />180 thermostat<br />3\" catalytic converter<br />Cat-back exhaust<br />Flowmaster<br />\"Fool you can bet, that I can dance underwater and not get wet\"
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
