I am trying to get my passenger side valve cover off so I can check to see if I have a bent pushrod or lifter damage, I can't figure out how to get the bracket out of the way so I can get to that last bolt in the valve cover....can anyone help? BTW, its a '98 Bird!
I need some help guys!!!
Your are talking about the engine lifting bracket on the back of the engine? Yeah, it can be a pain in the arse... There should be 2 bolts in the back that you need to get to. I had a hard time getting it off, that is why it never went back on.
Just feel around with your fingers, find the bolts, and you should be able to get a ratchet back there on it.98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
