Ive been having a rough cold start idle for quite a while. Until a couple days ago the misfire (P0300) code jumped at me. Today switched the plugs, inspected the wires, took the coils and icm to Autozone to be checked and they all passed.. But I still have the misfire code with a rough idle and gets worse as I press the gas. Is there anything else that I should look at???
P0300 Code HELP!
Re: P0300 Code HELP!
Fuel injectors could cause the PO300 , I would start with them.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
I would check the ohms and might as well try the clicking to see if it works.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Ohh and another thing! Try seafoaming it, and see if that'll clean up your injectors, upper intake, Valves, and combustion chambers. Just an Idea, and its cheap. There was a great link on how to properly do it on the LS1 forum I believe.
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
