difference between a 97 camaro 3800 and the 2000-02 camaro 3800? - FirebirdV6.com/CamaroV6.com Message Board
  • difference between a 97 camaro 3800 and the 2000-02 camaro 3800?
    I'm interested in Hypertech's Maxenergy programmer but its only available for 2000 and up camaros with the 3800V6 and mine is a 97 camaro with the 3800. I would like to know the difference between the two engines and if I can make mine the same so I can tune it with the power programmer.
    Re: difference between a 97 camaro 3800 and the 2000-02 camaro 3800?
    Might as well get hptuners for your car, it won't pay off trying to get yours 00' and up. You'll have to sell yours and get a 00' and up most likely.
      what is the difference between the 2 engines though?
        The intakes ,TB, wiring and pcm. too much to do for a programmer. Might as well get the real deal and go Hptuners.
          whats the difference between the intakes?
            The intakes on the 98' and above are straight while the 97' is slanted , the throttle bodies are DBW while 97' is cable.
              99-02 straight - drive by wire
              95-98 angled - cable
                Thanks I get confused on the 98' cars.
                  Either way, a very limited programmer is 300-350, while HPT is 500-650 and basically limitless.
                    HPTuners is compatible with 97& up so I'd go that route.
                    96 White M5 Camaro. Manual everything. Magnaflow cat, dynomax dual outlet axle back. Swapped to a disc rear with 3.42s and a torsen differential, kyb gr2 rear shocks, moog rear endlinks.
                      96's work with a 97' PCM also.
