Unscrew antenna? - FirebirdV6.com/CamaroV6.com Message Board
Unscrew antenna?
  • Unscrew antenna?
    I tried unscrewing my antenna off to put a universal car cover on it. I wrapped a towel around it and then took a pair of pliers to try and unscrew it...The antenna never moved, and the paint still came off of it. I was afraid to try again before I knew for sure it did screw off. My antenna does screw off right?
    1998 Arctic White Camaro<br />3.8L V6 M5<br />Flowmaster 80 Series with 3\" tips<br />Whisper Lid w/ K&N<br />Flowtech Cutout<br />Free-Ram Air Mod<br />Blue Underbody Neon Kit<br />3 MTX 6000 10\" Subs<br />Rockford 800a2 Amp<br /><a href=\"http://photos.yahoo.com/jeep327\" target=\"_blank\">My Camaro</a>
    <blockquote>quote:</font><hr>Originally posted by Camaro3.8L:
    My antenna does screw off right?<hr></blockquote>
    It should. I have a '98. It starts to come loose on its own after a while. I can tell because you can hear it vibrate/rattle in its socket if you bump it. Every once in a while I have to tighten it back up.
    The part that turns should be the part with the flats on it, at the bottom of the antenna shaft.
    \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
      I had to cut mine out :( The antenna had rusted/bonded/siezed to the mount. I had to cut it off at the base of the antenna so I could pull the bottom of the mount from the inside of the car. Now I have a fake power antenna looking thing rigged up. Radio works fine so I will leave it for now.Fake Antenna
        geez, i can't believe the antenna is that hard to screw off... i can take mine off easily with my fingers. you are turning it the right way.... right? :D lefty loosey, righty tighty [img]graemlins/fluffy.gif[/img]
        Kyle M<br />--------------<br /><a href=\"http://grdws6.netfirms.com\" target=\"_blank\">2002 Trans Am WS6</a> (silver, A4) - lid, cutout, stage 3 shift kit, 12 bolt, vig 3200, tranny cooler, bmr sfc/stb, torq thrust ii. <b>12.688 @ 106.47mph -=- 1.756 60\'</b>
          <blockquote>quote:</font><hr>Originally posted by GrdLock:
          geez, i can't believe the antenna is that hard to screw off... i can take mine off easily with my fingers. you are turning it the right way.... right? :D lefty loosey, righty tighty [img]graemlins/fluffy.gif[/img] <hr></blockquote>
          Hehe, yea I was saying that "lefy loosey,..." phrase the whole time I was trying. Never budged.
          Backfire, I love the creativity with that "power antenna" look [img]graemlins/rofl.gif[/img] . I guess Im gonna try again tommorow when it's light out, I'm really thinking about getting a power antenna now (a real one :D ), but gotta see how cheap I can get one for. Thanks for the help.
            I take mine off every time I go through a car wash, never thought it was that hard.
            ~chris~ 98 Cayenne red Camaro 3800 A4, 3:08, T tops Borla cat-back, wisper lid K&N, Bilstine shocks, Dunlops all around. <br />AOL IM: chevyboyz24
              if you're trying to put a cover on it, cut a hole where the antenna would go.
                <blockquote>quote:</font><hr>Originally posted by GregWS6'01:
                if you're trying to put a cover on it, cut a hole where the antenna would go.<hr></blockquote>
                I would do that but this car cover says its for cars 12'-14', and my car is about 16.5' so I just wanted to see if it would still fit ok b/c I'm not too worried about the lower part of the car being covered. But if I didn't like the way it fit, I didn't want to mess up the cover.
                  Well, the last time I had removed the antenna was probably 5 years ago. I guess that lead to it locking up. I was trying to remove it because the mounting feet underneath were putting a crease in the body panel. I even resorted to holding the lower part with Vice-grips and a closed end wrench on top with no luck :( Thats when I busted out the Dremel!!
                    I broke mine off my '94 a couple of years ago. It, too, was rusted onto the mount, and my dad & myself found this out the hard way when the antenna broke at the bottom :(
                    2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
                      LIQUID WRENCH!!! Let it soak for 24 hours, then hit it with the proper sized crescent wrench.
                        I tried WD40 and PB Blaster and neither made a difference.
                          You should install a power one.... if you can..
                          2006 Mustang Premium GT - Legendary Green - LLR#00321
                          Tint: %5 Rear/Louver & %35 doors, BBK CAI w/Brenspeed XCALII tune, Sill inserts,
                          Shorty Antenna, Billet Locks, JBA Exhaust- The quest continues
                            <blockquote>quote:</font><hr>Originally posted by Backfire:
                            I tried WD40 and PB Blaster and neither made a difference.<hr></blockquote>
                            Aw, man. If the Blaster didn't free it up, nothing will. Break out the cutter.
                              First, I don't know why he wants to take the antenna out?
                              By the way, does any one get whistling noise from your antenna? When I go faster than 80, I get that wind noise, and not sure if it's the antenna or the door.
                              Sunny Cali, T-top is the way to go! \'96 V6 3.8.
                              • LETZRIDE
                                New Owner!
                                by LETZRIDE
                                4 days ago
                                Little work today
                              • LETZRIDE
                                by LETZRIDE
                                Building the Tom Henry RS
                                By: Hib Halverson
                                02-07-2020, 10:30 PM
