woot woot .......crap - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: woot woot .......crap
    Originally posted by sunset
    beleave it or not thats what i did so thats all good now but how does the goose neck come out of the valve cover ??? cause im leaking oil out of it o and thank all of you who helped me out i really appreaciat it
    you need a valve cover breather... check ZZP thats where I got mine..
    1999 Firebird W68<br /> <a href=\"http://www.cardomain.com/ride/995565\" target=\"_blank\">http://www.cardomain.com/ride/995565</a> <br />-Derek
    • #17
      yea you need to do the PCV mod and a valve cover breather for sure
      If you did the JohnD wrap then yea you have to grind down below the oil filter for clearance
      http://www.bowtiev6.com/
      • #18
        are you the one who bought my kit? haha
        Dave:
        00 Supercharged Camaro - RIP
        97 Turbo Camaro - Sold
        • #19
          yea i am you forgot the 6ribed pully but i picked one up
          • #20
            oh my bad haha. i thought i had everything in there.
            Dave:
            • #21
              please help me to stop the code. The number is p1514 that code causes the ses light and the redused power light to come on and then it starts miss firing anny help would be much appreaciated thanks :rant:
              p.s. my yahoo account is confusednfocused same for aim as wel thanks again
              • #22
                common FI issue for 99+ cars
                do you have hptuners? Do you have a blow off valve or bypass valve?
                • #23
                  i had that too. :)
                  http://www.fullthrottlev6.com/forums...ighlight=p1514
                  I have an idea.. I still have my computer tuned for that blower, I can sell it to you for $90 shipped. Might save you a big hassle tuning, or at least give you a good head start.
                  Dave:
                  • #24
                    yes i have hp tuners and i could one of yall long in to aim its quicker
                    would that work cause mines a bird and a manual yours was an auto sry i havent looked into doing a pcm swap that much
                    p.s. thanks guys
                    • #25
                      get into hptuners, go under engine diag. then there is a tab for PO1514 code, max that whole table to the max that it allows. Either will be 4.1 or 512 depending on the format your car reads it in
                      • #26
                        512 and when i down load this in my car it will fixit right and anny thing elce i need to know ??? sorry i do use search im just not verry good at it and i forght about fullthrottlev6 thanks guys
                        • #27
                          I don't think this issue has been covered on this site, maybe 1 or 2 times before, so no biggy ;)
                          It should take care of your issue unless there is something else mechanically wrong with the car or another code
                          • #28
                            what 97yrs4life said is what you should do, yes. sorry i havent been on AIM in a while. And yea, I forgot you had a manual... so the pcm swap wouldnt work :(
                            Dave:
                            • #29
                              pcm swap would work, just would have to zero out the trans tables to make it work with a manual. However your pcm is probably tuned for the cam and such as well that you were running in it so it would be slightly different for his setup.
                              Dave, if you have hptuners you could send him your bin and he could look at it for pointers otherwise
                              • #30
                                thats always an option too. thanks 97rs4life.
                                sunset: just lemme know what youd like me to do and id be happy to help you.
                                Dave:
