what size cold piping are you using on your turbo kits i've read that 2.5" piping is only good for 400hp
What size cold piping
Re: What size cold piping
Alot of guys run 2.5-3"...either one, works awesome. With the 2.5" tho, you see a little quicker spool rate then the 3"...i would only go with 3" if you plan on pushing a ton of PSIJuiced Rally Red 98 A4<br /><br />Way too much to list....<br /><br /> <a href=\"http://www.cardomain.com/ride/2263415\" target=\"_blank\">http://www.cardomain.com/ride/2263415</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 hour ago
