Hey guys what is going on. ok i have finally decided to put a turbo on the v6 :D however in the starting my parts list i have gotten stuck. First off i can't seem to fine #36 injectors? two, the Cam. i was looking though the cam bible and i came on Intence Stage 1X Turbo Cam and of course the ZZP GT1 Cam witch cam would be better? i am going to run about 10 PSI though Abbott Raceing heads ( stage 2 ) and last but not least after looking for the Valve train there are just so many to choose from Where is hands down the best place to get a new train, and sence abbott puts on 130 LB springs do i need to get a bigger timing chain and sprokits? thanks for the help.
Trying to get a list together for a turbo.
Re: Trying to get a list together for a turbo.
just get abbots FI cam
and you will need a double roller timing chain for those springs.www.turbov6camaro.com
1997 3800 Series II Camaro
go onto clubgp.com, you will find 36# gtp injectors for like 40-60 bucks
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...5 hours ago
