How do vacuum operated parts work on a boosted engine? Like the brake booster, cruise control, etc.
How does vacuum work on a boosted engine?
<blockquote>quote:</font><hr>Originally posted by North Cali Autocrosser:
How do vacuum operated parts work on a boosted engine? Like the brake booster, cruise control, etc.<hr></blockquote>
Good question.... That was one of my questions for the ATI beta kit too. No answer yet.
The booster will hold vacuum because of a one-way valve in the vacuum line. That's why you still have power brakes when you first get in the car, before you start it. Also, if you let off the gas before you hit the brakes, the engine will start making vacuum again. So the booster should be ok.
Cruise (especially uphill at interstate speed) is one I'm still curious about. I'm thinking it won't hold.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
One way check valve...the booster should have a built in check valve so should the tranny modulator ( I am assuming the 4L60-e has the vac. signal)and the purge canister...
JohnD is right as soon as you get of the gas, vacuum "should be created" easily...THE ORIGINAL 3800SII turbo...<b><i>NOW SERIES-III</i></b>
The only time you should be under boost is WOT, and nobody brakes @ WOT [img]smile.gif[/img]2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Originally posted by Dominic:
The only time you should be under boost is WOT, and nobody brakes @ WOT [img]smile.gif[/img] <hr></blockquote>
so hypotheticly, if you were powerbraking on your auto and you smashed the throttle the breaks would give out all together and youd launch forward?
not really the brake booster mainly assists in applying the brake, I don't think it has much to do with holding it, though one thing I am curious about is doing a heel toe downshift, I guess so long as when you blip the throttle that you don't get into boost it would all be good..-Brad
2000 V-Star Custom 1100
:rock:
Vacuum is the exact opposite of boost. Once you hammer it (if you watch on the boost/vacuum gauge), it actually will go into boost. Under normal conditions, vacuum is normal measured around 17-20" and fluxuates as you increase the throttle.
I hope that helped to explain it for you.
Take care,
Tim<b>AOL:</b> OneBadAzzGT<p>1998 Supercharged Geee Tee (Powered by 2000 SOHC Engine) <br /> <br /><b>[i]1st shakedown pass:</b>12.4@114
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
