I got rid of my 7th injector set up and will be fabricating a 12 injector intake for my turbo 3500 intake. The stock 6 injectors will remain in the original location and 6 will be mounted in the plenum pointed right at the intake runners. I can keep my SMT6 tuner to control the added injectors, since the SMT6 will support up to a maximum 6 injectors. Pictured is my drilling template I will be using to keep all the holes spaced evenly.
12 Injector 3500 Intake
Re: 12 Injector 3500 Intake
Cool idea, what size injectors do you plan to run?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Drilled out holes and grinded to an oval shape to allow the bungs to go in on an angle.
It has pros and cons. It's much easier to tune, there's no tuning problems with idle and cold start up as with bigger injectors. All I need to tune is for when I am in boost. The stock tune and emissions is still the same, no need to be concerned at inspection time. I can upgrade to larger injectors without removing the plenum. Using larger injectors is less complicated installing and removing and the stock location is better.
After drilling all the pilot holes I used a pilot counterbore to finish the job.
Careful attention to squareness and depth checking when using my dewalt milling machine.
That's pretty awesome actually- now just replace those top injectors with nitrous jets :stp:
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 day ago
