replacement serpentine belt for the Powerdyne?? - FirebirdV6.com/CamaroV6.com Message Board
  • replacement serpentine belt for the Powerdyne??
    I"m looking for a serpentine belt replacement for the Powerdyne SC setup,
    Any ideas???
    headers, high flow cat, slp loudmouth
    powerdyne supercharger 6psi
    GT2 cam. all done by myself :banana:
    Hell yea
    Re: replacement serpentine belt for the Powerdyne??
    Take it off an take to a part store they should be able to match. 0r wrap string around all pully and measure for belt length
    1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
      With the JD wrap I ran a 103.0" , 103.5" to a 103.8 depending on the brand of belt. This was with a 2.6" pulley.
        2.6" pulley is that the 6 psi ????
        Hell yea
          No, 3.12" pulley is stock 6 PSI. If running that one I would try 104.0" belt with the JD wrap, if stock no wrap 104.5 is the belt lenght its the size for a 95' cobra with a/c if I remember correctly.
            it depends on what brackets you have, if you have the new one from GVP then you will need a 5061038 dayco. In other words a belt that is 103.8"
