I'm getting a whine from my heater when I put it on 3 or 4. It only does it on the heater not the ac. I checked the squirrel cage and it was squeaky clean with no debris in any part of the assembly. The sound seems to come from behind the fan switch itself. Any ideas?
heater whine
Re: heater whine
if you have a pioneer head unit they are prone for problems but it is possible with other head units also. it is most likely a bad ground. the way to fix that is to wrap a piece of wire around the rca terminals on the back of the head unit and reground it to somewhere with a solid frame. This will fix many whine problems. the other thing you can do for a cheap easy fix is go to radio shack and get a ground loop isolator. I guarantee you this will fix your problem. what speakers are whining. are they just door speakers or are they after market subwoofers? if u have any ?'s feel free to contact me. im a professional.
-Dave
Re: heater whine
I checked the speakers and it's not coming from the speakers, it seems to be coming from behind the heater switch I don't think the squirrel cage is bad because it has been doing this since I bought the car 3 years ago. I can't figure this out.
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
