HID headlights - FirebirdV6.com/CamaroV6.com Message Board
HID headlights
  • HID headlights
    I have heard of some people taking their sealed beam headlights and drilling them to accept hid bulbs:has anyone tried this or is there a writeup?
    Re: HID headlights
    http://forum.camarov6.com/showthread.php?t=81804
    Not sure how different the sealed beams are between the Camaro and Firebird, but this is all you have to do. If you don't want to do that, then you can buy some sealed beam conversions from eurolamps.com. They just use a clip to retain the bulb, so it is easier to change when it comes time.
    '99 Mountaineer AWD 5.0 - 4300K HID, Some Bolt-ons
    '97 RS - HPTuner, Bolt-ons
    '09 WRX - Aesthetic mods
      Re: HID headlights
      The link posted are not HIDs. They are Silverstars.
      I think it would be safer to buy the sealed beams from Eurolamps if you are considering HIDs. The reason I say it is safer is that HIDs project light differently than Silverstar halogens and stock housings are not designed to project HID light properly nor aim it properly, so therefore you will blind everyone on the road and you will run oncoming drivers off the road. Projector housings are designed to help focus the light much better. You can buy them from www.eurolamps.com. I just bought a set used for cheap that look stock but are aftermarket for my 8000Ks...
      I know of a set of housings available used for $20 if you are interested...
        Re: HID headlights
        Those housings you have pictured are not projectors, those are still reflectors like the stock glass housings. These are projectors, and these are what HID's where designed for:
        You are correct about the information of the differences though. This method here is the only way to properly retrofit HID's into Firebirds:
        http://www.ls1tech.com/forums/appear...-write-up.html
        Any other way of swapping out to HID's is wrong, and unsafe for all other drivers on the road.
        <b>1995 Pontiac Firebird</b> || 3.4L V6
          Re: HID headlights
          On my 96' Camaro, my 6000 HID's are in stock housings the fogs and low beams, I haven't had a problem with blinding people. Most the new cars out have blinding headlights that are worse than mine. I just about get blinded everytime I drive at night from someones stock headlights. But I do have headlight covers I can put on if I want to dim the light some.
            Re: HID headlights
            I realize that. But installing a bulb in a housing isn't any different between the two...
              Re: HID headlights
              True. All I was trying to point out is that HIDs are much more powerful than silverstar halogens and they require some special treatment.
                Re: HID headlights
                sooo true, i actually have 12000k hids on my low beams and they do not blind other drivers,since the housing is not made for it it actually dissipates the light and are not as bright as they should be,and yes other new cars are alot worst at blinding people,so if you want HID's or silverstars(which i have for sale 9006) just pop out your seal beams and put in the new bulbs and seal them with RTV high heat sealant,thats what i have and it works great for me.but then again i believe you have a firebird so it may be different.
                  Re: HID headlights
                  Originally posted by Richardcoelho View Post
                  sooo true, i actually have 12000k hids on my low beams and they do not blind other drivers,since the housing is not made for it it actually dissipates the light and are not as bright as they should be,and yes other new cars are alot worst at blinding people.
                  The stock housings are reflector housings that reflect the light in many angles and directions. They don't dissipate light. It's just not concentrated in one specific area like projectors.
                  '99 Camaro
                  '04 Saab 9-3 Aero
                  '90 Audi Coupe Quattro
