ok so a few weeks ago i came out to my car having a dead battery i was like wtf i get it jumped and it making this weird noise lift up the hood to find that my head light motor is spinning with the head lights off. so i disconnect the motor. i thot it was a worn gear so thats why its not turning off. well today i went to autozone and bought a new motor. well this motor is doing the same thing it just spins. how can i fix this?
headlight problem
Re: headlight problem
If it's making that grinding noise.... then the plastic gear inside is stripped. That's what makes the noise. New or not. It's entirely possible the gear stripped the first time you flipped the switch. I rebuilt mine with new plastic gears, and two days later one stripped again.
Eventually bought the brass gears. A little pricey. ($30 each I think?) But not an issue since.
Originally posted by 96firebird311 View PostIf it's making that grinding noise.... then the plastic gear inside is stripped. That's what makes the noise. New or not. It's entirely possible the gear stripped the first time you flipped the switch. I rebuilt mine with new plastic gears, and two days later one stripped again.
Originally posted by 95firebird3.4 View Postno it not gears b.c if i plug it into the driver side its fine and the motor is spinning with the headlights off
Does it start spinning immediatly after turning off the the lights, and does it actually raise and lower in sync with the other light?
Originally posted by fishin View PostI have had the motor apart and back together every possible way and I still get one light up and one light down. any ideas? Thanks.
WHY!!! are you responding to a 3 year old thread???Team NoVa
Originally posted by Red&Black_Attack View PostWHY!!! are you getting so worked up over what goes on, on the internet???Last edited by flamingchicken; 10-25-2011, 05:47 PM.Team NoVa
Originally posted by flamingchicken View PostHEY!!! how about stop being a tool!-Jarred '70 Pontiac LeMans | '89 Firebird Formula 350
There is nothing to help here, the problem was solved in 2008!!!
Oh and name calling on the internet makes you look stupid.Team NoVa
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...6 days ago
