Not sure if this is the right spot for this but, I'll go with it anyway. The battery is always getting dangerously low when I come to a complete stop. The lights dim, the blinker slows down, and my heat slows too. It seems like the alternator isn't charging it or whatever, because everytime I step on the gas a little it will go up, and everything will start working normal again. I haven't really looked into it yet but if someone can give me a start on what to check or if they know what it is, it will be very helpful. Thank you.
Battery Problems
Re: Battery Problems
Sounds like your alternator is about to kick-the-bucket. The alternator basically runs all of the electrical system(s) when the engine is running. The battery is there just to start the car.sigpic
a fully charged battery will read 13.6 volts on a voltmeter and will not drop below 8 volts when cranking the engine
Do you have any extra electrical accessories...like an Amplifier?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
could be a bad battery drawing hard on the alternator try to recharge.
check your connections if the amp & batt are new2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
are you gonna repeat everything I say? lol2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6are you gonna repeat everything I say? lol08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
most cars are running maiily off the batt when idling because of the way there wound(to put out more amps at crusing rpm) a fully charged batt is 12.6 any higher is a surface charge that will disapate fairly quickly. soorry for any typos i dont have my glasses on and can hardly read the screen
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...1 week ago
