Does anybody have one? A buddy of mine has one in his 89 camaro, and I was wondering if it is possible to put one in a 1997 camaro, and if so how would you go about doing it. Thanx
Push Button Start
greenmaro24 has one i believe. here is the link to his cardomain - greenmaro24. he has some pics of it so i'd say just shoot him an email or something and ask him about it.1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
Currently, I have it wired so that the key has to be put in and it has to be turned to the "On" position. By doing this, the VATS systems is still enabled.
Some people may say, "Well what's the point if you still have to put in and turn the key?" The point is it's unique and more importantly I like it.
Also, you can wire it so that it bypasses the VATS system. To do so, you must first measure the resistance of the chip in your key. Then you match up resisters to get the same value of the chip in your key. After doing so, you then plug the resistors in the shape of a U inline of the small connector that runs up to the steering colunm.
Soon I'll probably re-wire mine this way. However, I'll also wire in a switch(which I will hide) that will have to be flipped, to close the circuit and enable the button to work.Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...2 days ago
