Draw on the Camaro - FirebirdV6.com/CamaroV6.com Message Board
Draw on the Camaro
  • #16
    Over 24 hours and still starting up , going to try 2 days.
    • #17
      That's awesome Steve. Good to know things are working out.
      • #18
        Let it sit for 2 days, wouldn’t start, hit the on button on the remote and it started right up. My stereo even had the time and my settings. I’d recommend it , if you have battery problems. Here’s the one I got.
        https://a.co/d/3LKA2lE
        • #19
          Picture of install please.
          Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
          Raven
          • #20
            I’ll get a picture today Robert, it just goes on a top mount battery on the negative side then just install you original negative on the other post , then just run the red wire to the positive post. That’s it. Before I bought this one, I tried a cheaper one off EBay , didn’t work right so they refunded my money. It didn’t have the cutoff at 11.9 volts either. So pretty glad I came across this one.
            • #21
              Here’s some pictures, one of these days I’ll clean up my wiring.
              • #22
                Forgot - you moved your battery to the trunk. I still have the factory type side post.
                Raven
                • #23
                  Yes, but you still can fit a top post battery up front, I had the yellow top Optima battery up there. I also think they have the top post terminals for the side post battery. So you could hook it up. It’s on the negative post so don’t really have to worry about sparking anything. I’ll search around for you on the posts. Next time you replace the battery get one with top and side posts comes in handy.
                  • #24
                    something like this then just get another negative terminal to attach the original negative cable to the new battery post. I like the posts with the stud on
                    https://www.walmart.com/ip/EverStart...able/497929686
                    • #25
                      I actually have a set - on my spare battery for charging.
                      Raven
                      • #26
                        Amazon has 3 units that all look the same but different brands??
                        Raven
                        • #27
                          I posted the link to the one I got, it’s the Matel one.
                          • #28
                            Did you see the other brands of the same unit? If so, why did you get the matell?
                            Raven
                            • #29
                              Didn’t check out the others, I had bought one on EBay and it didn’t work, also it didn’t have the cutoff at 11.9 volts. I’m happy with the Matell .
