Why does the PCM have to be retuned if you swap the A4 to the M5?
Tranny PCM Retune
Re: Tranny PCM Retune
because the computer will still think you have an auto trans and throw a million codes, also your speedo will be wayyyyyy off
__________________
Already anwsered by Meatyshells up top to the same question, but I'll add to this also since I have swapped trannys M5 to A4, the timing and fuel tables are different and will run like crap. Plus the tons of codes, this should answer why the computer needs to be reflashed or have the correct PCM for the tranny.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Correct, make sure it has your year vehicle and gear ratio though, or your speedo will be off.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You'll have to get a 97' PCM , might look at PCM4less and get a PCM and have them program the gears for ya you'll have to give them your tire diameter and gear ratio then they can program it correctly, and some small stuff like fans ETC they can tune too.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Read the stickey on 96-97 pcms in the PCMS & SENSORS section.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
