trouble with clutch master cylinder removal - FirebirdV6.com/CamaroV6.com Message Board
  • trouble with clutch master cylinder removal
    got everything disconnected. that was easy. getting the damn star washer off of the U clamp is a different story.
    on a 96 camaro... how the hell do you get the "plate" off of the master cylinder. the star washer is placed inbetween the firewall and the plate that i can't remove. does anybody know what im talking about? my digital camera is broken. on install university ...
    http://www.installuniversity.com/ins...r_cylinder.htm
    step six, figure five. mine is nothing like that. that plate does not budge and i dont see where it can be detached..
    any ideas? thanks in advance
    -tyler
    96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
    Re: trouble with clutch master cylinder removal
    i spun it with my fingers and pre much threaded it off
      well nevermind on that. a little brute force helped. wont be reusing that washer. heh.
      okay new problem.. i dont have enough room to remove the damn cylinder. i either have to remove steering linkage or header. definitely dont want to do header. i yi yi. any hints?
        i did mine yesterday morning and i manages to kind turn it and i got it out but if you cant at all to remove the steering linkage remove the bolt completely and make sure you dont turn the steering wheel id take the key out so it locks otherwise you will break your clock spring
          sweeet.. well you see... im incredibly strong and brute force usually breaks things.. but the master cylinder can take a hell of a beating if you're just gonna replace the whole thing anyways...
            well here is the damage...
            quick question tomham, did the master cylinder come with the reservoir, mastery cylinder AND the steel braded hydraulic line? if so where did you order it? gmpartsdirect?
              i ordered it from the dealer im pre sure it will be cheaper somewhere else
              i needed it ASAP tho and yes it came with all that the autoparts stores dont they are only the master cylinder the only way to get the braided steel lne was to buy the entire assembly from GM and all i needed was the hose
                it is one hell of an expensive hose :(
                • Andy H
                  Hello everyone!
                  by Andy H
                • 3.4 slow to go
                  hey there strangers!
                  by 3.4 slow to go
