clutch issues - FirebirdV6.com/CamaroV6.com Message Board
clutch issues
  • clutch issues
    Well I replaced my stock clutch in december with a SPEC stage 2, and I was in kind of a hurry so I might have over looked a few things. Back in january I started hearing a squeeking noise at idle and when I would push the clutch pedal in the noise would go away. It still makes the noise, not all the time though. Well about a week ago it started making a ticking noise when I take off in first gear, it just goes tick tick then it goes away. So I'm going to rip my tranny out and try to see what's wrong. Should I get my flywheel resurfaced again??? Also I reused the stock flywheel bolts and the bolts that hold the pressure plate to the flywheel. Should I go and get new bolts???
    1997 Chevrolet Camaro
    Re: clutch issues
    its most likely the throwout bearing, did you replace it when you changed the clutch?
    yes, you should get new flywheel bolts, they are made to stretch when torquing them down, they are not reusable.. im surprised you didnt snap any when putting them back in.
    i used the same bolts for the PP to the flywheel with no problem
    if you arent changing the clutch plate, there is no need to resurface the flywheel.
    if i were you, i would recommend getting a new slave/to bearing kit
      Re: clutch issues
      The spec stage 2 kit came with a pilot bearing, throw out bearing, clutch disk and pressure plate. What is a slave to bearing kit???
        Re: clutch issues
        a slave cylinder that already comes with a throwout bearing on it
          Re: clutch issues
          i have reused my flywheel bolts for i dont know how many times, and for i dont know how long
          just have to put a little locktite on them
            Re: clutch issues
            you better hope they dont back out on you, the bolts are a stretch type, when you torque them, they stretch out. if you re-use them, they will become really weak
            i snapped two in my crank, luckily there was just a tiny bit sticking out and i was able to use a bolt-out kit to remove them
              Re: clutch issues
              What were you using to tighten the crank bolts? A sledgehammer? :eek:
                Re: clutch issues
                a torque wrench
                  Re: clutch issues
                  they looked like regular bolts to me *shrug*
                  havent had a problem with my grippy aftermarket clutch and launches at the track
                    Re: clutch issues
                    a torque wrench
                    Those are some pretty stout bolts. I've used 300 FT LBS air impact guns to put on flywheel/flexplate bolts and never snapped them. Maybe your turkey wrench is off... Is it a clicker or does it have the pointer?
                      Re: clutch issues
                      it is a click one
                      all i know is i had it set to however many ftlb it calls for, and when i tried to do the "additional 15*" or whatever it is, the bolt just got very loose and snapped
                        Re: clutch issues
                        Probably a good idea to buy some ARP bolts next time. They are pretty heavy duty. If you are driving it now, I guess it doesn't matter.
                        I have 2 click type Snap On torque wrenches ($$$$). You have to have them recalibrated once in a while - if you use them in an industrial environment. They also say to never use one of these to take off any bolts/nuts. I guess it messes up the calibration. I am trying to figure why the bolts snapped. Usually they tear out the crank threads. Eh, you were lucky.
                          Re: clutch issues
                          i got flywheel bolts at a chevy dealership because i didnt have enough time to order bolts, and none of the parts stores carried them, i asked if i could use grade 8 bolts, and they said i probably could, but they wernt sure
                            Re: clutch issues
                            a torque wrench
                            Are you a gorilla?
                            Shiiit, when I did mine, I probably pulled it 15+ times and never had issues with those bolts, other then installing them and tightening the ones on the very top. Didnt even use loc-tite
                            After a while i just said fugg it and left the top one out.
                            I tightened the crapp out of those bolts too and nothing broke
                            *Matt
                              Re: clutch issues
                              Originally posted by StrtRacer98 View Post
                              Are you a gorilla?
                              you left a flywheel bolt out?
                              why didnt you just spin the engine and put it so the bolt would be on the bottom?
                              remind me to never let you work on my car.
                              and i have read many threads about people snapping flywheel bolts
