done with my conversion! - FirebirdV6.com/CamaroV6.com Message Board
  • done with my conversion!
    finished tonight, but still have a few questions:
    my car seems to be slower(low end wise, its awesome after like 3k rpms), idk if im not having used to having a clutch or what. guess it could be the pcm also. not a huge loss of power, but yeah idk. my speedo isnt working either so it doesnt help any.
    its still kinda hard to shift into first sometimes - maybe some air still in the lines?
    downshifting is kinda hard and will sometimes knock the shifter out of gear
    turn signals dont work anymore
    have to manually turn on lights now, i know they dont come on with the ebrake on, but when i take it off they still dont come on and i have to turn the knob
    1999 v6 Camaro M5
    Automatic to Manual converted
    Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
    !cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
    Re: done with my conversion!
    how do you like all that chest hair you grew?
      hahaha, oh its nice
      1999 v6 Camaro M5
        Did you check or change the oil in the trans you put in?
        The automatic let the RPM rise faster down low because the converter slips and multiples torque.
        Did you plug in the VSS on the tail shaft of the transmission?
        The daytime running light module is behind the radio, you might have knocked one of the plugs on it lose.
          your stops on your shifter may be set bad, thats why its coming out of gear.
            i put in new ATF. didnt measure exactly, but i put 3 quart bottles, then about another half of one. had to be around 3.4 quarts.
            yeah i plugged the VSS in, but i probably switched the wires up when i was making the extension.
            1999 v6 Camaro M5
              already checked that, but ill double check
              1999 v6 Camaro M5
                For your speedo, you need to take your 99' VSS sensor out of your old A4 and put in the 00' M5.
                  ohhhh
                  1999 v6 Camaro M5
                  • LETZRIDE
                    New Owner!
                    by LETZRIDE
                    5 days ago
                    Little work today
                  • LETZRIDE
                    by LETZRIDE
                    Building the Tom Henry RS
                    By: Hib Halverson
                    02-07-2020, 10:30 PM
