I am looking to replace the rear end from my RS with one from a Z28 in order to get LSD, 3.43 gears, and disk brakes. Which years will fit? Am I bound to 93-97, or can I go anywhere from 93-02?
What rear end will work?
Re: What rear end will work?
i think 3.42 will be the hard part.
if you go 98+ you will need to modify your brake setupLast edited by TheGr8Schlotzky; 12-25-2007, 08:13 PM.
any rear will bolt in the only thing is the brakes if it is a 4 channel (traction control) depending if your car has traction control or not you may need to swap brake lines i could tell you how to do it however i did it for my car
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
Actually, I kind of ran into an unforseen problem with mine. I got a rear end from a '95 Z28, and I believe I'm going to have to pull the axles again to swap the brake system onto the rear end, because of the parking brake on the 98+ (or 97+, I can never figure out what changed when). Not really a big deal, just means I'll have to remove the rear end cover again and put in more fresh gear lube which is kind of a pain.
you could get new ebrake cables for like 40 from autozone thats what i did cause i had a rear out of a 98 in my 94 but that is up to you and your budget
Originally posted by Shad0wguySo the main issue with a 98-02 rear would be the e-brake?Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
does you car have one brake hose going from the body to the rear end or two brake hoses, another way to tell is if you have a TCS switch inside the car, let me know what you find and i will explain after
