7.5 & 7.625? - FirebirdV6.com/CamaroV6.com Message Board
7.5 & 7.625?
  • 7.5 & 7.625?
    what does the 7.5 and 7.625 mean when your buying gears?
    example: GM 10 Bolt 7.5" & 7.625 " differential
    <a href=\"http://www.cardomain.com/ride/2151539/1\" target=\"_blank\">http://www.cardomain.com/ride/2151539/1</a>
    Re: 7.5 &amp; 7.625?
    its the diameter of the differential
      so is 7.5 a 3 series and 2.625 is a 2 series?
        just the diameter like he said, either can be for 2 or 3 series carrier
          how can you tell if its three or two series do they call it somthing else?
            series is based on the gears, 2 series is anything 3.08 and below, 3 series is 3.23, 3.42 and up, I believe there is a 4 series but you'd have to do more research on that.
            7.5 and 7.625 diff is the size of the rear end, like a ford 9 inch.
            I'm pretty sure the gears and carrier are the same for a 7.5 and 7.625. If you are buying gears and you currently have a 3.08 rear end and want to go up to 3.23 or 3.42's then you will also need to get a 3 series carrier.
            -Brad
            2000 V-Star Custom 1100
            :rock:
              yea but ive seen some people with 4.10 gears that go with a 2 series carrier same with 3.73s
              so what my question is: is their a name besides 2 series and where would you find those?
              or am i just totaly out of my mind. i could of sowrn i heard of that before though.:)
                yeah, you can get 3.73 or 4.10's for a two series carrier. Are you trying to get gears for your open differential?
                  no ive got a 2 series lsd
                    try this:
                    http://store.summitracing.com/egnsea...115+4294895863
                      i dont get it why is one more then the other? everything they say about it is the same on both of them. is one better than the other?
                        the cheaper sportsman gears are for "normal street-driven applications". The regular richmond gears can handle more for drag racing and such.
                          which do you think i should get? i hit the track very rarely and maybe race 10 times in a year
                            i'm sure you'd be fine with the sportsman but $40 more isn't much for some peace of mind.
                              Ok lets clear up a little confusion. The first part you said about series 2 being anything 3.08 and below is correct. However, the other part of that is if you are equiped with 3.08 or below gears from the factory you have a series 2 carrier with series 2 gears. If you are 3.23 or above from the factory you have series 3 gears with a series 3 carrier. If you have a series 2 carrier and want gears above 3.08 then just buy whatever gears you want (4.10, 3.73, ect) and make sure they are for a series 2 carrier. I know for a fact Strange sells gears in all ratios for both carriers. Check Thunderracing.
                              • LETZRIDE
                                New Owner!
                                by LETZRIDE
                                3 days ago
                                Little work today
                              • LETZRIDE
                                by LETZRIDE
                                Building the Tom Henry RS
                                By: Hib Halverson
                                02-07-2020, 10:30 PM
