i think i might have glossed over my clutch disc. i put it in first and it is hard to take off slowly. then, when i shift through second and into third and mash on the gas, the RMP's crawl upward very fast but my acceleration is the same, and when i let off ther gas, the engine speed drops back down to where it should be. i don't know if i have to buy a new clutch or not because it'll cost 200 buck from auto zone or if i could just replace the disc with someone elses? help me please.
Glossed Clutch :-(
well it definitely sounds like it's slipping.. and also sounds like you don't have much time left.. the best way to do this would be do the whole clutch kit.. and throw out bearing at once..
but my first question would be what kind of mileage does your car have on it?? .. really doesn't make much of a difference though I guess.. if your clutch is slipping you need a new clutch and pressure plate bare minimum provided it has gone bad......-Brad
2000 V-Star Custom 1100
:rock:
wow!.. man if that clutch is original it ain't glossed it's wore out!..lol..-Brad
:rock:
That puppy is definatly worn out1996 Silver Camaro, Y87, M5, cammed..<br />N/A Best Time: 14.012 @ 98.59<br />195 rwhp / 233 ft-lbs b/f heads/cam<br />Check out my site <a href=\"http://silver3800.cz28.com/\" target=\"_blank\">http://silver3800.cz28.com/</a>
I think I might have "smoked" my clutch. I was raqcing my car at No Problem Raceway, I lanched the car approx 2000 rpm I felt like the tires spun through 1st shift light came on shift to 2nd, then also most right into 3th and 4th. shift light came on shifted into 5th. Finally stop spinning but lot of smoke from under the car. The car is a 2002 with 18000 miles and this was the 7th pass on the car. If I need to replace the clutch what should I use. Thanks T.Ray
[ November 04, 2002: Message edited by: TRAYCAMARO2002 ]</p>
well, mine does it during normal driving. i think it happened when i did a one- eighty and i kept it in first and smoked the tires for about 1/8th of a mile. (showed those high schoolers). now, especially when it is cold, it slips under granny driving conditions usually in third. guess iu gotta shell it out huh?
<blockquote>quote:</font><hr>Originally posted by TheBulldog:
well, mine does it during normal driving. i think it happened when i did a one- eighty and i kept it in first and smoked the tires for about 1/8th of a mile. (showed those high schoolers). now, especially when it is cold, it slips under granny driving conditions usually in third. guess iu gotta shell it out huh?<hr></blockquote>
not even sure that is what did it, I ahve never heard of a stock clutch lasting that long, on a sporty car.
by Andy HIts been a while since I've been on the forum. Hope everyone is doing well. I still have my camaro! Unfortunately, the slave cylinder and clutch has went...4 weeks ago
