I've searched everywhere. looks like 93-97 v6 manuals and autos used the same crossmembers. What about 98-02, I think autos and manuals are different but are they the same as v8's? Spent over three hours searching now!
Transmission crossmember differences
Re: Transmission crossmember differences
Originally posted by Kenneth View PostI've searched everywhere. looks like 93-97 v6 manuals and autos used the same crossmembers. What about 98-02, I think autos and manuals are different but are they the same as v8's? Spent over three hours searching now!
I mounted my t-56 crossmember by bolting on the passenger side, and completely cut off the drivers side leg of the brace. I then bolted on the drivers side to the car and tacked some plate between the two pieces of the crossmember. Then I removed the crossmember and put it on the work bench to finish welding it up. It actually worked pretty well, and everything bolts right up.
The V8 auto is a direct bolt-in replacement for the V6 T5 on a 96. No modification necessary. Then installed a 1LE trans mount - also a direct bolt-in.
.Robert - owner www.FirebirdV6.com "Mid-life crisis? I'm way beyond that!"
Raven
by ssms5411Went ahead and moved my starter wire from the back, to the front again since it had no effect on my drain on the battery. Also made me nervous driving...3 days ago
